tgenty
Jun 01, 2020Star
Orbi RBR50 seems stuck in boot loop
Hi, After my orbi performance dropped, I restarted the router hopping it will fix it. However it doesnt fully restart now. The power led is solid green and the ring is solid white for like 20 sec...
tgenty
Jul 22, 2020Star
Well I can't just give up on it yet.
So I've opened the router, found the serial pin on the motherboard and bought a USB-serial cable. Now I can access to the bootloader console but I lack knowledge on this.
I managed to confirmed that firmware upload with tftp works well. However everytime it boots, it ends up with a "data abord" followed by a reset.
Here are the logs of the tftp upload, firmware V2.5.1.32 (I've removed most of the dot while receiving the firmware for clarity)
Format: Log Type - Time(microsec) - Message - Optional Info
Log Type: B - Since Boot(Power On Reset), D - Delta, S - Statistic
S - QC_IMAGE_VERSION_STRING=BOOT.BF.3.1.1-00096
S - IMAGE_VARIANT_STRING=DAAAANAZA
S - OEM_IMAGE_VERSION_STRING=CRM
S - Boot Config, 0x00000023
S - Core 0 Frequency, 0 MHz
B - 261 - PBL, Start
B - 1339 - bootable_media_detect_entry, Start
B - 129185 - bootable_media_detect_success, Start
B - 129199 - elf_loader_entry, Start
B - 131586 - auth_hash_seg_entry, Start
B - 133734 - auth_hash_seg_exit, Start
B - 169767 - elf_segs_hash_verify_entry, Start
B - 283099 - PBL, End
B - 283124 - SBL1, Start
B - 371628 - pm_device_init, Start
D - 6 - pm_device_init, Delta
B - 373192 - boot_flash_init, Start
D - 593 - boot_flash_init, Delta
B - 380023 - boot_config_data_table_init, Start
D - 74730 - boot_config_data_table_init, Delta - (419 Bytes)
B - 460626 - clock_init, Start
D - 7523 - clock_init, Delta
B - 471575 - CDT version:2,Platform ID:8,Major ID:1,Minor ID:0,Subtype:1
B - 475057 - sbl1_ddr_set_params, Start
B - 480042 - cpr_init, Start
D - 2 - cpr_init, Delta
B - 484532 - Pre_DDR_clock_init, Start
D - 5 - Pre_DDR_clock_init, Delta
D - 13144 - sbl1_ddr_set_params, Delta
B - 497800 - pm_driver_init, Start
D - 2 - pm_driver_init, Delta
B - 568859 - sbl1_wait_for_ddr_training, Start
D - 28 - sbl1_wait_for_ddr_training, Delta
B - 585341 - Image Load, Start
D - 785135 - QSEE Image Loaded, Delta - (262104 Bytes)
B - 1370979 - Image Load, Start
D - 888 - SEC Image Loaded, Delta - (0 Bytes)
B - 1380825 - Image Load, Start
D - 1185462 - APPSBL Image Loaded, Delta - (413427 Bytes)
B - 2566718 - QSEE Execution, Start
D - 58 - QSEE Execution, Delta
B - 2572986 - SBL1, End
D - 2291853 - SBL1, Delta
S - Flash Throughput, 342 KB/s (675950 Bytes, 1976018 us)
S - DDR Frequency, 672 MHz
U-Boot 2012.07 [Barrier Breaker unknown,unknown] (Jul 29 2016 - 22:37:42)
U-boot dni1 V1.1 for DNI HW ID: 29765352; NOR flash 32MB; EMMC flash 4000MB; RAM 512MB
smem ram ptable found: ver: 1 len: 3
DRAM: 512 MiB
machid : 0x8010001
NAND: Nand Flash error. Status = 64
ONFI Read id cmd failed
ONFI probe failed
SF NAND unsupported id:ff:ff:ff:ffSF: Unsupported manufacturer ff
ipq_spi: SPI Flash not found (bus/cs/speed/mode) = (0/0/48000000/0)
0 MiB
MMC: qca_mmc: 0
PCI0 Link Intialized
In: serial
Out: serial
Err: serial
machid: 8010001
flash_type: 1
Net: MAC0 addr:b0:b9:8a:61:af:26
PHY ID1: 0x4d
PHY ID2: 0xd0b1
ipq40xx_ess_sw_init done
eth0
Hit any key to stop autoboot: 0
(IPQ40xx) # fw_recovery
eth0 PHY0 Down Speed :10 Half duplex
eth0 PHY1 up Speed :100 Full duplex
eth0 PHY2 Down Speed :10 Half duplex
eth0 PHY3 Down Speed :10 Half duplex
eth0 PHY4 Down Speed :10 Half duplex
The Router is in TFTP Server Firmware Recovery mode NOW!
Listening on Port : 69, IP Address: 192.168.1.1 ...
Rcv:
32 MB reveived
Done!
Bytes transferred = 43518081 (2980881 hex)
mmc_read will run command: mmc read 0x871cfd78 0x2a22 0x100
MMC read: dev # 0, block # 10786, count 256 ... 256 blocks read: OK
HW ID on board: 29765352+0+4000+512+2x2+2x2+4x4
HW ID on image: 29765352+0+4000+512+2x2+2x2+4x4
Firmware Image HW ID matched Board HW ID
mmc_read will run command: mmc read 0x871cfd90 0x2a22 0x100
MODEL ID on board: RBR50
MODEL ID on image: RBR50
Firmware Image MODEL ID matched Board model ID
mmc erase 0x4622 0x14c05
MMC erase: dev # 0, block # 17954, count 84997 ... 84997 blocks erase: OK
Alive-timer 57
NmrpAliveTimerBase 15
Copy image to Flash... mmc write 0x84000080 0x4622 0x14c05
MMC write: dev # 0, block # 17954, count 84997 ... 84997 blocks write: OK
boot_partition_set 1
mmc_read will run command: mmc read 0x871cfb50 0x2a22 0x100
Burn BOOT PARTITION DATA (= 110101) into ART block
mmc_sect_erase will run command: mmc erase 0x2a22 0x100
MMC erase: dev # 0, block # 10786, count 256 ... 256 blocks erase: OK
mmc_write will run command: mmc write 0x871cfb50 0x2a22 0x100
MMC write: dev # 0, block # 10786, count 256 ... 256 blocks write: OK
Done.
Alive-timer 22
Done
Rebooting...
resetting ...
Valid chip addresses: 27 48and the log of the restart (I've removed lots of MMC read log lines for clarity)
B - 17387 - bootable_media_detect_success, Start
B - 17401 - elf_loader_entry, Start
B - 19819 - auth_hash_seg_entry, Start
B - 21967 - auth_hash_seg_exit, Start
B - 56125 - elf_segs_hash_verify_entry, Start
B - 169316 - PBL, End
B - 169341 - SBL1, Start
B - 257848 - pm_device_init, Start
B - 259418 - boot_flash_init, Start
D - 594 - boot_flash_init, Delta
B - 266256 - boot_config_data_table_init, Start
D - 73578 - boot_config_data_table_init, Delta - (419 Bytes)
B - 345709 - clock_init, Start
D - 7518 - clock_init, Delta
B - 356654 - CDT version:2,Platform ID:8,Major ID:1,Minor ID:0,Subtype:1
B - 360134 - sbl1_ddr_set_params, Start
B - 365119 - cpr_init, Start
B - 369609 - Pre_DDR_clock_init, Start
D - 13143 - sbl1_ddr_set_params, Delta
B - 382875 - pm_driver_init, Start
B - 453700 - sbl1_wait_for_ddr_training, Start
B - 469956 - Image Load, Start
D - 785174 - QSEE Image Loaded, Delta - (262104 Bytes)
B - 1255632 - Image Load, Start
D - 886 - SEC Image Loaded, Delta - (0 Bytes)
B - 1265457 - Image Load, Start
D - 1185486 - APPSBL Image Loaded, Delta - (413427 Bytes)
B - 2451373 - QSEE Execution, Start
B - 2457640 - SBL1, End
D - 2290290 - SBL1, Delta
S - Flash Throughput, 342 KB/s (675950 Bytes, 1976099 us)
DRAM: 512 MiB
machid : 0x8010001
ONFI probe failed
0 MiB
MMC: qca_mmc: 0
In: serial
Out: serial
Err: serial
machid: 8010001
flash_type: 1
PHY ID1: 0x4d
PHY ID2: 0xd0b1
eth0
Client starts...[Listening] for ADVERTISE...TTT
Retry count exceeded; boot the image as usual
nmrp server is stopped or failed !
Read BootPart from BOARD DATA...
mmc_read will run command: mmc read 0x871cfca8 0x2a22 0x100
boot partition : 1
BootPart = 1
Loading DNI firmware for checking...
MMC read: dev # 0, block # 17954, count 256 ... 256 blocks read: OK
MMC read: dev # 0, block # 18210, count 256 ... 256 blocks read: OK
MMC read: dev # 0, block # 18466, count 256 ... 256 blocks read: OK
MMC read: dev # 0, block # 102690, count 256 ... 256 blocks read: OK
MMC read: dev # 0, block # 102946, count 256 ... 256 blocks read: OK
MMC read: dev # 0, block # 17954, count 1 ... 1 blocks read: OK
** rootfs address : 0x843bffc0 **
## Checking Image at 84000000 ...
FIT image found
FIT description: ARM OpenWrt FIT (Flattened Image Tree)
Image 0 (kernel@1)
Description: ARM OpenWrt Linux-3.14.77
Type: Kernel Image
Compression: gzip compressed
Data Start: 0x840000e4
Data Size: 3524167 Bytes = 3.4 MiB
Architecture: ARM
OS: Linux
Load Address: 0x80208000
Entry Point: 0x80208000
Hash algo: crc32
Hash value: 4b698f35
Hash algo: sha1
Hash value: 439cf7c76bf93d7dd525f87978dbfb0a718c7bf7
Image 1 (fdt@1)
Description: ARM OpenWrt qcom-ipq40xx-ap.dkxx device tree blob
Type: Flat Device Tree
Compression: uncompressed
Data Start: 0x8435c86c
Data Size: 39067 Bytes = 38.2 KiB
Architecture: ARM
Hash algo: crc32
Hash value: 2fbe7ae7
Hash algo: sha1
Hash value: 10a7fad2926d324e8b06b192c3531c391f78a6ed
Image 2 (fdt@2)
Data Start: 0x84366214
Data Size: 38617 Bytes = 37.7 KiB
Architecture: ARM
Hash algo: crc32
Hash value: c0098bb9
Hash algo: sha1
Hash value: baf8b2904ec24c626934dabf5d6815eadedadc29
Image 3 (fdt@3)
Data Start: 0x8436f9fc
Data Size: 42101 Bytes = 41.1 KiB
Architecture: ARM
Hash algo: crc32
Hash value: 0109faf0
Hash algo: sha1
Hash value: 34ee6bdafd6315d361d6aa99b5ad45a9944b32dd
Image 4 (fdt@4)
Data Start: 0x84379f80
Data Size: 34248 Bytes = 33.4 KiB
Architecture: ARM
Hash algo: crc32
Hash value: 0fa6ee98
Hash algo: sha1
Hash value: dcec33a744cfed6a21c9a9be313791f98b1081ff
Image 5 (fdt@5)
Data Start: 0x84382654
Data Size: 34407 Bytes = 33.6 KiB
Architecture: ARM
Hash algo: crc32
Hash value: 96f6beb1
Hash algo: sha1
Hash value: 3a938e8901b816f4fa7d73aacbc3e2b54422c5d0
Image 6 (fdt@6)
Data Start: 0x8438adc8
Data Size: 34547 Bytes = 33.7 KiB
Architecture: ARM
Hash algo: crc32
Hash value: ce835bd9
Hash algo: sha1
Hash value: f48535f83fe16c4d3471b18ddab6dfa5d1a633e7
Image 7 (fdt@7)
Data Start: 0x843935c8
Data Size: 38588 Bytes = 37.7 KiB
Architecture: ARM
Hash algo: crc32
Hash value: bb010bc8
Hash algo: sha1
Hash value: a52a0530438afae1fe5fed13cb380503d0ee576b
Image 8 (fdt@8)
Data Start: 0x8439cd90
Data Size: 38467 Bytes = 37.6 KiB
Architecture: ARM
Hash algo: crc32
Hash value: 311234ec
Hash algo: sha1
Hash value: c7be34f25ccb51f0d0eaa6985af77d30b872eaef
Image 9 (fdt@9)
Data Start: 0x843a64e0
Data Size: 38165 Bytes = 37.3 KiB
Architecture: ARM
Hash algo: crc32
Hash value: f91b53ee
Hash algo: sha1
Hash value: 7f783a91e42dc651bb82f01479f5207640db0d53
Default Configuration: 'config@1'
Configuration 0 (config@1)
Description: OpenWrt
Kernel: kernel@1
FDT: fdt@1
Configuration 1 (config@2)
Kernel: kernel@1
FDT: fdt@2
Configuration 2 (config@3)
Kernel: kernel@1
FDT: fdt@3
Configuration 3 (config@4)
Kernel: kernel@1
FDT: fdt@4
Configuration 4 (config@5)
Kernel: kernel@1
FDT: fdt@5
Configuration 5 (config@6)
Kernel: kernel@1
FDT: fdt@6
Configuration 6 (config@7)
Kernel: kernel@1
FDT: fdt@7
Configuration 7 (config@8)
Kernel: kernel@1
FDT: fdt@8
Configuration 8 (config@9)
Kernel: kernel@1
FDT: fdt@9
## Checking hash(es) for FIT Image at 84000000 ...
Hash(es) for Image 0 (kernel@1): crc32+ sha1+
Hash(es) for Image 1 (fdt@1): crc32+ sha1+
Hash(es) for Image 2 (fdt@2): crc32+ sha1+
Hash(es) for Image 3 (fdt@3): crc32+ sha1+
Hash(es) for Image 4 (fdt@4): crc32+ sha1+
Hash(es) for Image 5 (fdt@5): crc32+ sha1+
Hash(es) for Image 6 (fdt@6): crc32+ sha1+
Hash(es) for Image 7 (fdt@7): crc32+ sha1+
Hash(es) for Image 8 (fdt@8): crc32+ sha1+
Hash(es) for Image 9 (fdt@9): crc32+ sha1+
## Checking Image at 843bffc0 ...
Legacy image found
Image Name: ARM OpenWrt Linux-3.14.77
Image Type: ARM Linux Kernel Image (lzma compressed)
Data Size: 39585792 Bytes = 37.8 MiB
Load Address: 40908000
Entry Point: 40908000
Verifying Checksum ... OK
boot partition : 1
MMC read: dev # 0, block # 17954, count 7680 ... 7680 blocks read: OK
data abort
pc : [<87303568>] lr : [<87304250>]
sp : 871efd60 ip : 871f0ad3 fp : 87303557
r10: 00000000 r9 : 00000002 r8 : 871eff60
r7 : 871f0ab8 r6 : 87360cec r5 : 871f0ab8 r4 : 8735e6a4
r3 : ffffffff r2 : 00000158 r1 : 00000000 r0 : 87360cec
Flags: nZCv IRQs off FIQs off Mode SVC_32
Resetting CPU ...
resetting ...
Valid chip addresses: 27 68Here is the printenv command:
(IPQ40xx) # printenv baudrate=115200 bootcmd=reset_i2c; mii write 0x0 0x0 0x0800; sleep 1; nmrp; bootdni; bootm 0x84000000 bootdelay=2 delenv=mmc erase 0x1622 0x200 ethact=eth0 flash_type=1 ipaddr=192.168.1.1 loadaddr=0x84000000 machid=8010001 serverip=192.168.1.10 stderr=serial stdin=serial stdout=serial Environment size: 313/262140 bytes
I executed the bootcmd manually and I've confirmed that the "data abord" is issued by the "bootm 0x84000000".
Any help would be appreciated.
fel0ncod3
Jun 26, 2022Aspirant
I purchased the serial cable as well and am able to plug into the Orbi via serial cable.
How did you get access to the console? Did you use Terminal or command prompt? Curious what commands you used.
Thnx!!
Thnx!!
- rayted-rJul 02, 2022Initiate
You guys really need to look up a guide for serial flashing. You don't just buy a usb-ttl serial cable and then figure out what to do. dd-wrt and openwrt usually have guides for when these things happen because they happen very frequently in the firmware flashing arena.
basically,
#1 install the right drivers for the usb-ttl, usually a "prolific pl2303" chip, so you want those drivers. newer drivers 2018+ will read cheap ones as fakes, but older drivers like older than 2017 should recognize it right. then set the rate to 115200 in device manager instead of the regular 9600
#2 download an interfacer like putty so you can interact with the serial console. both the serial and ethernet cable must be plugged in, so there are 2 cables interacting with the orbi. make sure you don't plug into the 3.3v on the serial or else you get the magic smoke. set the ip on network settings to 192.168.1.1 on gateway, 255.255.255.0 on subnet, 192.168.1.10 as the adapter's/yours. on putty, find the serial setting and turn the flow control to off and rate to 115200, and whatever com it says (copy the settings from device manager), then in the connection type click serial, host as 192.168.1.1 on port 69 (because netgear does port 69 on orbis for whatever reason)
#3 click open to show the interface and then power on the orbi. if nothing shows up, you prob need to switch tx and rx pins. you likely need a multimeter to know 1. which is ground first before 2. knowing what hot/3.3v is so you don't plug anything into that one. if you do it correctly, it should shove a whole lot of info on the console. to stop it all push ctrl c or any other button I think. type in "help" to show all the options, but you very likely only need "fw_recovery" and a tftp program to send firmware into it. If none of that works and the u-boot is corrupted, then all this effort was wasted and you likely need another rbr50/rbr40 with a good uboot to extract from and reflash. Unfortunately netgear does not provide bootloader download, nor does anyone else on the internet. At least, not yet.
That's probably most of it and you can probably find other missing info from the other serial unbricking guides. If you bought one off ebay just to try it, you're really gambling. Just like my dumb dumb butt. So far, I have had a 70% success rate with the other 30% being bad uboot.
- bonro001Jul 25, 2022Aspirant
Excellent post!
Where I get stuck is in the serial interface the boot loader will ask to press any key. Have tried several emulators, both on windows and OSX, can never press a key. Using N81 No flow at the proper speed. Feel like because I get to the prompt I can probably interrupt is if I could just press a key!!
Any ideas?
-So Close
- xray2Sep 27, 2022Aspirant
I assume if you have a bad uboot there is no reviving and it looks something like this...
S - QC_IMAGE_VERSION_STRING=BOOT.BF.3.1.1-00110
S - Reset status Config, 0x00000033
B - 85322 - bootable_media_detect_success, Start
B - 85336 - elf_loader_entry, Start
B - 189543 - auth_hash_seg_entry, Start
B - 191694 - auth_hash_seg_exit, Start
B - 363688 - elf_segs_hash_verify_entry, Start
B - 478097 - PBL, End
B - 478121 - SBL1, Start
B - 570161 - pm_device_init, Start
D - 9 - pm_device_init, Delta
B - 571663 - boot_flash_init, Start
D - 669980 - boot_flash_init, Delta
B - 1245990 - boot_config_data_table_init, Start
D - 104462 - boot_config_data_table_init, Delta - (419 Bytes)
B - 1353044 - clock_init, Start
D - 7544 - clock_init, Delta
B - 1364019 - CDT version:2,Platform ID:8,Major ID:1,Minor ID:0,Subtype:1
B - 1367425 - sbl1_ddr_set_params, Start
B - 1372517 - cpr_init, Start
B - 1376900 - Pre_DDR_clock_init, Start
D - 4 - Pre_DDR_clock_init, Delta
D - 13171 - sbl1_ddr_set_params, Delta
B - 1390196 - pm_driver_init, Start
B - 1461441 - sbl1_wait_for_ddr_training, Start
D - 27 - sbl1_wait_for_ddr_training, Delta
B - 1477620 - Image Load, Start
D - 912517 - QSEE Image Loaded, Delta - (262104 Bytes)
B - 2390564 - Image Load, Start
D - 899 - SEC Image Loaded, Delta - (0 Bytes)
B - 2400397 - Image Load, Start
D - 185410 - APPSBL Image Loaded, Delta - (414279 Bytes)
B - 2586233 - QSEE Execution, Start
D - 60 - QSEE Execution, Delta
B - 2592430 - SBL1, End
D - 2116421 - SBL1, Delta
S - Flash Throughput, 549 KB/s (676978 Bytes, 1231023 us)
B - 2605318 - Boot error ocuured!. Error code: 3027Thanks
