nickduts's avatar
nickduts
Orbi RBR50 Separate wifi bands
How do I separate my 2.4 and 5 GHz bands on my Netgear Orbi RBR50 system without them resetting again. I have done some research and found out how to separate them however after about 10minutes the 5g...
  • nickduts's avatar
    nickduts
    Nov 19, 2019
    Yes and no. Sometimes it switches in the same place and my link speed drops significantly and sometimes when I move. Honestly, the reason I was trying to fiddle with the bands is to maintain a higher and constant link speed. I feel like I may have solved this issue though, I went into the advanced settings and I've enabled 5ghz SSID broadcast, my phone has been on the 5ghz band since and my link speed is much better now. Thanks for the help and if you have any other ideas or find another solution, please do let me know.
