nickduts
Nov 19, 2019Aspirant
Orbi RBR50 Separate wifi bands
How do I separate my 2.4 and 5 GHz bands on my Netgear Orbi RBR50 system without them resetting again. I have done some research and found out how to separate them however after about 10minutes the 5g...
- Nov 19, 2019Yes and no. Sometimes it switches in the same place and my link speed drops significantly and sometimes when I move. Honestly, the reason I was trying to fiddle with the bands is to maintain a higher and constant link speed. I feel like I may have solved this issue though, I went into the advanced settings and I've enabled 5ghz SSID broadcast, my phone has been on the 5ghz band since and my link speed is much better now. Thanks for the help and if you have any other ideas or find another solution, please do let me know.
nickduts
I'm just trying to ensure that I have the highest speeds coming into my devices based on what they can use for example: My phone supports 5ghz and for some reason Orbi only puts it on the 2.4ghz band and I can't use the full potential of my phone or my router because my router isn't assigning the fastest band possible to my phone even though signal wise, the signal strength is fine with both hands.
CrimpOn
Nov 19, 2019Guru - Experienced User
The accepted understanding is that the device decides which WiFi channel to join, not the router. My Sony Xperia, for example, always connects to the Orbi at 5G. (as does my wife's iPhone & iPad, my Galaxy Tablet, my 2.4G/5G WiFi cameras, etc.) I suspect there is something else going on which is affecting your phone.
Have you tried "forgetting" the Orbi WiFi, locating the phone close to the Orbi and then searching for WiFi?
Mind sharing which brand/model of phone this is?
- nickdutsNov 19, 2019AspirantI see your point and what I've been noticing for the past couple of hours since I've tried separating the bands is that my phone switches between 2.4 and 5ghz quite frequently. My phone is a Huawei Mate20 Pro and I've never encountered connectivity issues of any kind with it however again, you make a good point. I wonder if there is any way to force it to stay on 5ghz...
- CrimpOnNov 19, 2019Guru - Experienced User
Does the phone switch when it remains in one spot?
- nickdutsNov 19, 2019AspirantYes and no. Sometimes it switches in the same place and my link speed drops significantly and sometimes when I move. Honestly, the reason I was trying to fiddle with the bands is to maintain a higher and constant link speed. I feel like I may have solved this issue though, I went into the advanced settings and I've enabled 5ghz SSID broadcast, my phone has been on the 5ghz band since and my link speed is much better now. Thanks for the help and if you have any other ideas or find another solution, please do let me know.
