Veets
Jun 23, 2020Aspirant
ORBI RBR50 set up as AP
Hi, I received newer Spectrum modem(HiTron Technologies Docsis 3.1 eMTA, E31N2V1) and seperate router(Pack Fast 5280/ SAGEMCOM /RAC2V2S) that replaced my UBEE(modem+router combo). I had my ORBI-RB...
- Jun 23, 2020
Veets wrote:This modem they sent only has 1 ethernet port, unfortunately. Maybe i can add a switch or something.
The router has several ports for more options
Exactly, that is the point of a modem. convert from coax to ethernet. If the three ethernet ports on the Orbi are not enough, most people add an inexpensive gigabit ethernet switch. 8 port models are under $30. An "unmanaged" switch is preferred.
CrimpOn
Jun 23, 2020Guru - Experienced User
My instinct would be to use their modem and ignore the router. Just plug the Orbi into the modem.
The "blue light" stays on for only a minute or two, and then goes out.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
- VeetsJun 23, 2020Aspirant
Ok, you answered the light issue-thanks
Thanks for option & idea
- CrimpOnJun 23, 2020Guru - Experienced User
