darrell2311
Jan 06, 2021Aspirant
Orbi RBR50 set up issues
I have had this model working in our old house in Denmark and installed it without issues. We recently relocated to a different country and having issues setting up the system again. The devices pa...
Jan 06, 2021Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Built in router here? If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
darrell2311 wrote:I have had this model working in our old house in Denmark and installed it without issues. We recently relocated to a different country and having issues setting up the system again.
The devices pair up, have reset the devices to default manufacturing setting but cannot seem to get the systemt to connect to my router / internet. I am no tech geek and would just like to get the system working again as we desperately need the system to work to get coverage around the house. Thank you
- vajimJan 06, 2021Master
Isn't talking about a double NAT a bit premature without answers to previous questions?
- darrell2311Jan 07, 2021Aspirant
Thank you guys for your responses. When referring to device, I am referring the Orbi router and the satelitte. These two seem to be connected to each other but someone the Orbi router cannot connect to the internet - and that's what is shown on the Orbi App when I go through the configuration process.
Like I said I am no techie so really appreciate the help.
Hi Furry,
Thanks for taking time to respond. I'll get you those details in a few hours when I am back home and have finished googling up all those terms :)
BR
- vajimJan 07, 2021Master
darrell2311 wrote:Hi Furry,
BR
Good luck
