vgmon's avatar
vgmon
Tutor
Jan 20, 2021
Orbi RBR50 setu but Satelitte the ethnetnet ports do not work
I read similar issues and tried to reste both router and sateitte. First I powered off the Modem and then turned on and waited and then followed instalataion of orbi Router and ten went upstairs to c...
  • vgmon's avatar
    vgmon
    Jan 27, 2021
    I called support and I extended my warranty. Got technical support. My firmware was updated according to the unit . Said latest update. When Tech helped they had another Firmware update and installed on both Router and satellite of Orbi. All ports on the router and satellitte now work with Android devices and laptop
    My issue has been resolved and I now have 2 years extended support
