drlopezmd
Dec 04, 2019Aspirant
Orbi RBR50 shows offline, but has Internet access
connected into modem and disconnected the separate spectrum wifi tower/router. have internet access. succesfully added two satellites. app says "internet:offline" . Does this matter? Does it aff...
Dec 04, 2019Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Then use the Orbi router in router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
drlopezmd wrote:connected into modem and disconnected the separate spectrum wifi tower/router. have internet access. succesfully added two satellites. app says "internet:offline" . Does this matter? Does it affect my wifi speed? I have 400 mbps down from the cable company but effectively only 130 due to configuration of my house, i believe, but i wonder if fixing the "offline" issue will help.
- drlopezmdDec 04, 2019Aspirant
Thank you. I will try later today and let you know.
