Brizz
Aug 05, 2019Aspirant
Orbi RBR50 Slow Connection
Hello, I'm currently subscribed to Xfinity (not by choice) with 150mbps internet speed. When I first installed my Netgear modem + Orbi Router, I was getting top notch speed and everything was awe...
Brizz
Aug 06, 2019Aspirant
Furry, i'm not using an ISP modem, I used to rent Xfinity's access gateway but upgraded to the CM1000 modem and my Orbi router is plugged straight into that.
Comcast said everything on their end looks great but since it's not their hardware, they can't help troubleshoot the system other than removing devices.
I tried to remove all but 2 devices (phone and hardwired iMac) and then I rebooted the router and I still was getting the same download and upload speeds. I'll do a factory reset this weekend when I have more time to reconnect my devices to the router. I'll keep this thread updated if I find any improvements.
I did turn off my guest wifi and will only turn it on when we have guests over. I've seen this has helped a few people but didn't do much for my performance. Maybe it will take some time to show?
Aug 06, 2019Guru - Experienced User
"ISP modem" is in reference to any modem used by the user. Weather ISP or user owned. It's all inclusive.
Try a factory reset and set up from scratch using the suggestions. Wired PC and stand alone speed test app.
