space_rover
Aug 12, 2020Follower
Orbi RBR50 slow download much faster upload
I'm currently recieving 11 mbps download, and 49.58 mbps upload, directly from the router unit via ethernet cable, and about half that via wifi. This issue has been occuring on and off for several mo...
Aug 12, 2020Guru - Experienced User
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Mstrbig
Aug 12, 2020Master
When you say router, do you mean Orbi router or ISP router. If Orbi router, what is it plugged in to? If you have an ISP modem, plug directly into that and tell us your speeds.
