GuyCal
Oct 25, 2022Follower
Orbi RBR50 slow download speeds with new BT Smart Hub2
Hi, I have just had BT Full Fibre 900 installed with BT Smart Hub2 router and at router I get 700+ MBps download speed. Previous ISP was also Full Fibre and with that I achieved good download speed...
Oct 25, 2022Guru - Experienced User
You might ask the ISP if the router hub is needed and if there is a separate ONT, if you can remove the router hub and put the RBR in it's place. Something to ask about.
GuyCal wrote:
Hi, I have just had BT Full Fibre 900 installed with BT Smart Hub2 router and at router I get 700+ MBps download speed. Previous ISP was also Full Fibre and with that I achieved good download speed in AP mode on Orbi RBR50 - but now I get 110MBps Upload and sub-30MBps download. I have updated the Orbi firmware and checked the ethernet connections to the BT Hub, but cannot improve the Orbi download speed. I also tried disabling the BT router WIFI - also no improvement on Orbi download speed. Any suggestions gratefully received.
