DHARMESHSHAH
Nov 22, 2020Aspirant
ORBI RBR50 SLOW SPEED
Hello All, I am currently using Netgear Orbi RBR 50 which is connected to a Fiber Modem. The speed provided by ISP is 1GBPS. While i am getting around 980MBPS download and 500MBPS uploads using ...
Nov 23, 2020Guru - Experienced User
There is a more recent FW update that you can try:
If not, I would downgrade to v16.
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
DHARMESHSHAH wrote:Hello All,
While i am getting around 980MBPS download and 500MBPS uploads using wired connection.
However, while on Wifi 5Ghz i am getting max of 200 MBPS and while being connected on 2.4Ghz i am getting max of 10-20Mbps download speeds. This is irrespective of being connected to primary router of satellite. Same speeds if i am latched to either of the routers.
My Firmware version is V2.5.2.4
Hardware version: RBR 50
Backhaul status is Good.
Other status:
Daisy Chain: Enabled
Implicit Beamforming: Enabled
Mu-Mimo: Enabled
Fast Roaming: Enabled
Please advice how i can increase my wifi speeds.
Thanks you in advance.
