hammadbadozai
Feb 06, 2020Aspirant
ORBI RBR50 Slow wifi speed over Wifi
Hi Guys- I bought this router on Dec 23rd 2019 and since that day, i have called in netgear like 20 time as they have horrible cuistomer support. I consistantly,am having low speed on my wifi. I ...
Feb 06, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
