LuisJAbellon
Oct 10, 2019Aspirant
Orbi RBR50 Slow WiFi
xfiniti Xfi modem/router in bridge mode, service is 600 Mbps RBR50 with one satellite in router mode connected to modem via Cat6 cable. Doing speed test with Samsung S10 via Ookla app I get 250...
LuisJAbellon
Oct 11, 2019Aspirant
Why is xFi on brdige mode an issue?
Why is teh latest verssion v2.3.5.30 an issue?
Retired_Member
Oct 11, 2019
LuisJAbellon wrote:Why is xFi on brdige mode an issue?
Do a search in this forum. Numerous posts about problems with v2.3.5.30.
Most will agree IF possible, it's best to run the Orbi router with no other routers. Do a search.
- LuisJAbellonOct 12, 2019Aspirant
ISP modem/router is on bridge and WiFi radios are turned off.
Orbi is in router mode.
connected with Cat6 cable, 6 feet apart.
service is 600 Mbps......speed test max is 300 Mbps, connected to base in the 5 GHz band.
i have rebooted both units.
Where red is my speed going?
If version currently used is a problem, what version should I use?
The ISP unit is running in bridge mode.
