LuisJAbellon
Oct 10, 2019Aspirant
Orbi RBR50 Slow WiFi
xfiniti Xfi modem/router in bridge mode, service is 600 Mbps RBR50 with one satellite in router mode connected to modem via Cat6 cable. Doing speed test with Samsung S10 via Ookla app I get 250...
LuisJAbellon
Oct 15, 2019Aspirant
Hello, Tried everything suggested.......moved ISP router (in bridge mode) 8' appart.....connected to Orbi with Cat6 cable......I see no improvement.
Now I have ordered a CAT 8 cable......next will be to use ISP touter as router and Orbi as AP.
Any other suggestions?
Retired_Member
Oct 15, 2019
LuisJAbellon wrote:Hello, Tried everything suggested.......moved ISP router (in bridge mode) 8' appart.....connected to Orbi with Cat6 cable......I see no improvement.
Do you need the ISP router?
- LuisJAbellonOct 15, 2019Aspirant
No. I have the ISP router. Wireless and wired connection from ISP router shows speeds of over 500 Mbps. I have 600 Mbps service.
- Retired_MemberOct 15, 2019
LuisJAbellon wrote:No. I have the ISP router. Wireless and wired connection from ISP router shows speeds of over 500 Mbps. I have 600 Mbps service.
Can you run your network WITHOUT the ISP router?
The ISP Router/Modem is the Gateway to the internet. Running in Bridge mode. Orbi runnig in Router mode.
So, no, I cannot access the internet without it.
