deanandkt
Oct 13, 2018Aspirant
Orbi RBR50 Slow Wired WAN after 2.2.1.210 Upgrade
My system updated automattically this week from 2.1.4.16 to 2.2.1.210. I have ATT Fiber and would normally get 800/800 before the upgrade. After the upgrade my up/down is 30/300ish. I connected my...
- Dec 13, 2018
The Pace modem in DMZ Plus mode ended up being the issue. I posted a response twice indicating this but for some reason it never actually posted.
Oct 15, 2018Guru - Experienced User
You can revert back to v16 and see if that solves your problem.
You can see if blocking the autoupdater to prevent an update from going back to v210 works as well:
deanandkt
Oct 21, 2018Aspirant
I was able to get the Orbi system back on the .16 code, but the bandwidth was still a problem. My down for some reason is capped at 50Mbps. When plugged directly into my AT&T router, I'm still able to get 800/800. I did a factory reset and the 50mbps down was still in place.
I'm going to contact support about replacing it.
