deanandkt
Oct 13, 2018Aspirant
Orbi RBR50 Slow Wired WAN after 2.2.1.210 Upgrade
My system updated automattically this week from 2.1.4.16 to 2.2.1.210. I have ATT Fiber and would normally get 800/800 before the upgrade. After the upgrade my up/down is 30/300ish. I connected my...
- Dec 13, 2018
The Pace modem in DMZ Plus mode ended up being the issue. I posted a response twice indicating this but for some reason it never actually posted.
jarvis42
Nov 21, 2018Aspirant
After having slow wired (fine when connected directly to modem at 800+mbps, connected wired to Orbi was ~100mbps) & wireless speeds recently, I tried disabling Daisy Chain as suggested (it was shown as enabled). After Orbi rebooted, speeds went back up to what I expected.
Nov 21, 2018Guru - Experienced User
Crazy that Daisy Chain is effecting performance. Hope NG will fix this. Glad you got it working.
Enjoy.
