Randyincarmel
Jun 03, 2021Follower
Orbi RBR50 Slower WiFi than Wired
We just recently upgraded our service to 1Gig up and down. The Orbi router is showing around 900Mbps up and down, but it is producing a WiFi speed of around 250Mbps and 150Mbps (up). This is slower th...
Jun 04, 2021Guru - Experienced User
Wireless will never match same speed at 1Gb wired. 5Ghz AC devices max out at around 400-500Mbps. And not all wifi devices can do that. It all depends on support and design of the wifi device and connetion rate.
Mac connection rate on Orbi AC is 866Mbps. This is a connect rate between the Orbi system and your devices on 5Ghz only. This differs from actual bandwidth. https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
