kingmojo1197
Oct 15, 2020Aspirant
Orbi RBR50 slowing down network traffic
My ISP just upgraded me to gigabit internet, and when I plug my PC directly into the modem, I get speeds north of 900 mbps. When I plug the Orbi in, the speed test shows 700Mbps. Updated to the lat...
Mstrbig
Oct 15, 2020Master
kingmojo1197 wrote:My ISP just upgraded me to gigabit internet, and when I plug my PC directly into the modem, I get speeds north of 900 mbps. When I plug the Orbi in, the speed test shows 700Mbps. Updated to the latest firmware. Any traffic going through the Orbi, such as a PC run speed tests, also shows ~700. Why am I seeing such a degradation in performance? All connections are hard wired, and not going over wifi. Firmware is 2.5.2.4.
Who is your ISP and what equipment did they provide?
What device is your Orbi router connected to?
Disable Circle, Armor, Daisy Chaining, Fast Roaming, IPv6 and uncheck 20/40Mhz Coexistence.
Enable WMM, Implicit BeamForming, Mu-MIMO
Set Short preamble mode. Save settings, reboot Orbi.
If wired, what cable size was used, as wrong size can cause slow speed.
kingmojo1197
Oct 17, 2020Aspirant
So my ISP is Comporium, a local shop near Charlotte, NC. The actual modem I'm using is an Arris Touchstone CM8200.
- kingmojo1197Oct 17, 2020Aspirant
Oh, also, this is all wired. I'm using Cat6 cables, and only Cat6 cables. Further, This is doing the speed test on the Orbi itself in the web console. Plugging my PC directly into the Arris gives me the correct speeds that I expect.
OK, so I made the recommended changes. No difference. It appears that the Orbi can't handle gig internet? Do I need to find a different brand router?
- FURRYe38Oct 17, 2020Guru - Experienced User
Has a full power OFF of the RBR and modem for 1 minute been performed since last FW update?
Try a factory reset and setup from scratch. Be sure to not Enable Armor, Circle, QoS or Traffic Meter on the RBR after the setup wizard completes.
You might try V70 FW if your in the USA region or downgrade to v16.
The RBR does handle near 1Gb speeds:
