orbiuser13's avatar
orbiuser13
Orbi RBR50 slowing speeds down
Hi.  I have Comcast Internet with a brand-new Linksys CM3016 modem and a 250 Mbps package.  When I plug my desktop directly into the modem via Ethernet, a Speedtest shows speeds that actually approach ~300 Mbps.  However, when I plug the Orbi in to the modem, and my desktop into the Orbi, the speed slows to 90 Mbps.  Furthermore, my Wi-Fi speed - even when just a few feet away from my Orbi - is only ~30 Mbps.
My Orbi is running Firmware V2.1.2.18.  I also have a satellite Orbi two floors down, but I haven't even bothered testing down there considering how slow these speeds are.
I have to admit, I'm pretty disappointed considering how much I spent on these things.  Definitely not working as advertised.
Thanks for any help you can offer!
John
  • A wired speed limited to 90 Mbps usually indicates a problem with the cable or with the speed negotiation of the Ethernet ports.
    Replace all cables between the desktop, the Orbi, and the modem, and test again. Make sure all your cables are cat 5e or better cables.
    If that doesn't work, check the link speed on the desktop. It should show "1.0 Gbps"
    https://winaero.com/blog/see-the-ethernet-or-wifi-adapter-speed-in-windows-10/
    If your desktop has WiFi, turn it off when testing wired speed.
    If none of that works, try using a different LAN port on the Orbi for your desktop. It's possible the port is bad.
    • orbiuser13's avatar
      orbiuser13
      Thanks so much - switching the Ethernet cable between the modem and Orbi seems to have done it.  I appreciate the help!
