rlyoung1952
Nov 12, 2018Aspirant
Orbi RBR50 slowing speeds down
I am using a Orbi RBR50 Router with Comcast internet and every day or so it speed will drop to 40 to 50 MB download. I will reboot the router and my speed will increase back to the 175 MB range whic...
ekhalil
Nov 12, 2018Master
You probably have loops in the router that are loadng it, so a reboot refreshes the system until loops come back again.
What wired devices do you have connected to Orbi? Any wired mesh speakers?
Are you using wired or wireless backhaul?
Is Orbi set to Router or AP mode?
When you have an issue, do you see massive number of DHCP messages in Orbi Logs?
- rlyoung1952Nov 12, 2018Aspirant
I only have one device connect to the wired port of the router. It is a apple mini computer. Everything else is wireless. The backhaul is also wireless. I have attached the log file. It does not appear to be loaded but I am no expert on this.
