rlyoung1952
Nov 12, 2018Aspirant
Orbi RBR50 slowing speeds down
I am using a Orbi RBR50 Router with Comcast internet and every day or so it speed will drop to 40 to 50 MB download. I will reboot the router and my speed will increase back to the 175 MB range whic...
Nov 12, 2018Guru - Experienced User
What are your wired PC test speeds?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
rlyoung1952 wrote:
I am using a Orbi RBR50 Router with Comcast internet and every day or so it speed will drop to 40 to 50 MB download. I will reboot the router and my speed will increase back to the 175 MB range which I have. I have also restarted the Modem but that has no affect. It is only when I reboot the router does my internet speed goes to normal.
I am using V2.2.1.210 firmware.
Is anyone else haing this problem? Is there a fix?
- rlyoung1952Nov 12, 2018Aspirant
Arris SB6190.
Basicly the same.
House about 2200 Square Feet.
70 feet separation between satellite and router
Auto
Yes
If so, how many? 18 or more
What WPA security modes are you using? WPA2-PSK
When the problem arises all devices slow down going to the internet. If I am streaming a movie from my computer over WIFI there does not seem to be a problem. Only to the internet.
Thanks
- FURRYe38Nov 12, 2018Guru - Experienced User
Arris SB6190.
Be aware of this about your modem:
Basicly the same.
Try placeing the satellite a bit closer, 70feet maybe too far. Mines at 40 feet.
Auto
Yes
What channels are they using? You maybe getting some interferences and wifi congestion from neighbors wifi systems.
- FURRYe38Jan 24, 2019Guru - Experienced User
Any update or progress on this?
Arris SB6190.
Basicly the same.
Auto
Yes
Thanks
- lxjrFeb 18, 2019Tutor
I am having the same issue and according to support they cannot find a reason or a fix for this issue. I have to reboot everyday to get my speed back.
