rlyoung1952
Nov 12, 2018Aspirant
Orbi RBR50 slowing speeds down
I am using a Orbi RBR50 Router with Comcast internet and every day or so it speed will drop to 40 to 50 MB download. I will reboot the router and my speed will increase back to the 175 MB range whic...
rlyoung1952
Arris SB6190.
What are your wired PC test speeds?
Basicly the same.
House about 2200 Square Feet.
70 feet separation between satellite and router
What channels are you using?
Auto
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by?
Yes
If so, how many? 18 or more
What WPA security modes are you using? WPA2-PSK
When the problem arises all devices slow down going to the internet. If I am streaming a movie from my computer over WIFI there does not seem to be a problem. Only to the internet.
Thanks
Nov 12, 2018Guru - Experienced User
Arris SB6190.
Be aware of this about your modem:
Basicly the same.
Try placeing the satellite a bit closer, 70feet maybe too far. Mines at 40 feet.
Auto
Yes
What channels are they using? You maybe getting some interferences and wifi congestion from neighbors wifi systems.
