rlyoung1952
Nov 12, 2018Aspirant
Orbi RBR50 slowing speeds down
I am using a Orbi RBR50 Router with Comcast internet and every day or so it speed will drop to 40 to 50 MB download. I will reboot the router and my speed will increase back to the 175 MB range whic...
RPO
Jan 24, 2019Initiate
Same issue here. Comcast. Im topping at 90Mbps WIRED to the router. If I wire to the modem, I get 300Mbps. I have already tried a modem reset to no avail. What a huge dissapointment.
- FURRYe38Jan 24, 2019Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?What devices do you have connected to the Orbi system? Wireless and wired?
Try disabling IPv6.
Testing with a different PC show same problem?
Swap LAN cable beween ISP modem and router?
