JeffreyRoach
Feb 28, 2019Follower
Orbi RBR50 Solid White RIng
Powered the Orbi off and on this morning and the ring turned solid white. Rings on the two satellites were majenta. I read to do a factory reset and run through the setup again, but it won't factory reset. I held the button in for 2 minutes and nothing happened. I fear it's dead in the water. Any suggestions?
1 Reply
Sort By
- Chuck_MMentor
I would unplug everything from Orbi and wait 5 mins.
The plug it in to power only and do this process:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
If that doesnt work, I am afraid you may have a boat anchor.
