ChrisEchWH
Jan 29, 2021Aspirant
Orbi RBR50 specifically throttling MacBook Pros
I've been struggling with this for over 6 months, and am about ready to abandon Orbi & buy Eero, but before I do, I'll give the Orbi one last chance here. I have an RBR50 with 1 satellite & 1G se...
Jan 29, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
ChrisEchWH wrote:I've been struggling with this for over 6 months, and am about ready to abandon Orbi & buy Eero, but before I do, I'll give the Orbi one last chance here.
I have an RBR50 with 1 satellite & 1G service from ISP.
RBR50 is running on latest firmware (V2.7.2.102).
After I reboot the router, and generally for about 10 days thereafter, all is good: all devices in the house get full bandwidths via wifi, as expected. But then, for no apprent reason, usuallly between 1 & 2 weeks after the last reboot, and this change always happens overnight, I find that our MacBook Pros are throttled to <40Mbps, while our iOS and other devices remain unaffected.
I've seen other past posts about the same behavior, where updating to newer firmware helped: I started seeing this under an earlier version of the firmware, and the update did indeed fix it, but only for a while, and now, it's systematic that I'm ending up having to reboot the router at least every 2 weeks. A real pain since our whole house depends on bandwidth now with WFM under COVID, and each reboot inevitably disrupts various video meetings. This simply should not be happening with a supposedly top line product.
Advanced wireless config details shown in attached screenshot.
Is there a CLEAR fix, or should I just ditch Orbi & buy Eero?
