pkhatri
May 17, 2021Tutor
Orbi RBR50 spectrum not giving gigabit speed.
I have been using specturm 300MBPS service for past several years with no issues, Couple days ago upgraded my service to 1GB but not getting results. setup is RBR50 Router + 2 RBS50 Statalites Spe...
svetaketu
May 17, 2021Luminary
Hi pkhatri,
I maybe wrong but cat5 cable has a bandwidth of up to 100 MHz, supports 10 or 100Mbps speed.
And what are the specs of your wired and wireless network cards? What is the max speeds it can reach as per the manufacturers documentation? The P510 was released in 2016, so the network cards may not support the speeds you are expecting. Have you also tried updating the drivers?
The speedtest on the Orbi GUI is the speed from the Orbi to your Hitron modem. the speedtest on your pc is from the Orbi to your pc/device.
Hope this helps.
