VFMass
Feb 28, 2020Aspirant
Orbi RBR50 Speed Half ISP
I am using the RBR50 (V2.3.5.30). I have Verizon FIOS 1GB. When I run Google, Bing, Orbi speed tests, they all max out around 300MB. When I used verizon.com/speedtest it shows the router speed at 940...
VFMass
I believe that it's simply a modem—they installed the hardware years ago and I connect directly to the Orbi via CAT5e—which then goes to an unmanaged gigabit switch.
Feb 28, 2020Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
Have you powered OFF both modem and RBR for 1 minute then power ON the Modem and let it sync then power ON the RBR then test again?
Try a different PC or laptop to compare speeds.
VFMass wrote:I believe that it's simply a modem—they installed the hardware years ago and I connect directly to the Orbi via CAT5e—which then goes to an unmanaged gigabit switch.
- VFMassFeb 28, 2020Aspirant
The switch is a TP-Link 16-Port Gigabit Ethernet Unmanaged Switch (TL-SG1016D) and modem is Arris (ONT14842-VZ). Yes, for the power cycle!
- FURRYe38Feb 28, 2020Guru - Experienced User
This switch seems to have Green Ethernet features. "Innovative energy-efficient technology saves power consumption". Something that is known to cause some problems for orbi. https://www.tp-link.com/us/business-networking/unmanaged-switch/tl-sg1016d/
Have you directly connected your PC to the back of the ONT to check speeds. Then connect your pc to the back of the RBR to check speeds?
You might factory reset the RBR and setup from scratch as a last resort. Be sure to not use QoS, Traffic Meter, don't enable Armor or Circle.
Might update FW as well.
VFMass wrote:The switch is a TP-Link 16-Port Gigabit Ethernet Unmanaged Switch (TL-SG1016D) and modem is Arris (ONT14842-VZ). Yes, for the power cycle!
