MaguEbel's avatar
MaguEbel
ORBI RBR50 Speed lost after Firmware Update?!
Hey Folks,
I´m a little lost right now. We have a 100 MBIT/s internet connection here and normally in the farest corner of the property we still have at least 40-50 mbit with the ORBI-System (WLAN). But since an update of the firmware (the latest version) of the router the speed is not even half and the connection is totally unstable. Since almost simultaneously there was an firmware update of our fritzbox 7490 I don´t know what kind of changes may have caused the lost of speed and the instability of the connection.
Does anybody has an idea?
  • Retired_Member's avatar
    Retired_Member
    MaguEbel wrote:
    Hey Folks,
    Was the FW update pushed auto by NG or did you do it manually?
    • MaguEbel's avatar
      MaguEbel
      I´m regularly checking for updates over the ORBI-App...I updated when Iast checked a couple of days ago.
        Retired_Member
        Why?  Was your network working?
  • FURRYe38's avatar
    What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here? This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Is the Orbi system operating in Router or AP mode?
    Has a full factory reset on both router and satellite(s) then set up from scratch since last FW update?
    Update FW thru the routers web page with a web browser.
    MaguEbel wrote:
    Hey Folks,
