brightball's avatar
brightball
Orbi RBR50 speed seems to be degrading over time
I've had my Orbi RBR50 and 1 satellite for a little over a year now (March 2019). For most of that time, everything seemed to be working fine but over the last 3 months we started noticing problems o...
  • FURRYe38's avatar
    Possible that the RBRs WAN port is faulty if the connection status reads 100Mpbs. IT should be 1000Mpbs.
    You may want to contact NG support to see if they can help you or see what your options are.
