brightball
Jul 29, 2020Aspirant
Orbi RBR50 speed seems to be degrading over time
I've had my Orbi RBR50 and 1 satellite for a little over a year now (March 2019). For most of that time, everything seemed to be working fine but over the last 3 months we started noticing problems o...
- Jul 29, 2020
Possible that the RBRs WAN port is faulty if the connection status reads 100Mpbs. IT should be 1000Mpbs.
You may want to contact NG support to see if they can help you or see what your options are.
brightball
FURRYe38 wrote:What Firmware version is currently loaded?
v2.5.1.16
Cable Modem
Hitron Technologies, Inc, DOCSYS 3.1 eMTA, E31N2V1
What is the Mfr and model# of the ethernet switch in the configuration?
The wired only router that was just added is a Ubiquiti EdgeRouter 4 ER-4
and the switch connected to it is a Netgear ProSAFE GS108PE.
The Orbi has been tested while plugged into the Cable modem directly, directly into the EdgeRouter and into the switch. A computer plugged into the switch speedtests at the maximum 220. The Orbi is currently plugged into the ProSAFE switch and the indicator light is the Orange 100.What is the size of your home? Sq Ft?
I'm actually not concerned about the Wifi performance. The Wifi performance mirrors hardwired performance that I'm seeing through the Orbi and I'm testing within 5 feet with no obstructions. The satellite is currently turned off.Try disabling the following and see:
Just applied and retested. I don't see any noticeable difference.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026Just tried it. No noticeable effect.
Has a factory reset and setup from scratch been performed since last FW update?Yes. 4 days ago.
Jul 29, 2020Guru - Experienced User
- brightballJul 30, 2020Aspirant
I called and nothing could be done because it didn't have a hardware warranty unfortunately.
- FURRYe38Jul 30, 2020Guru - Experienced User
Well thats a shame. Sorry you can't get this fixed. Sounds like something faulty on the RBR. I would try to get it replaced or go with something new. You could use the RBR in AP mode and connect it using the LAN port but your top ring LED will be on PINK always. :smileyfrustrated:
Thanks for the tip! That actually worked and now that I'm plugged in through the LAN port I get full speed again.
