brightball
Jul 29, 2020Aspirant
Orbi RBR50 speed seems to be degrading over time
I've had my Orbi RBR50 and 1 satellite for a little over a year now (March 2019). For most of that time, everything seemed to be working fine but over the last 3 months we started noticing problems o...
- Jul 29, 2020
Possible that the RBRs WAN port is faulty if the connection status reads 100Mpbs. IT should be 1000Mpbs.
You may want to contact NG support to see if they can help you or see what your options are.
Jul 29, 2020Guru - Experienced User
brightball
Jul 30, 2020Aspirant
I called and nothing could be done because it didn't have a hardware warranty unfortunately.
- FURRYe38Jul 30, 2020Guru - Experienced User
Well thats a shame. Sorry you can't get this fixed. Sounds like something faulty on the RBR. I would try to get it replaced or go with something new. You could use the RBR in AP mode and connect it using the LAN port but your top ring LED will be on PINK always. :smileyfrustrated:
- brightballJul 30, 2020Aspirant
Thanks for the tip! That actually worked and now that I'm plugged in through the LAN port I get full speed again.
Sounds good. Put a peice of tape over the WAN port and put a post it note on the back mentioning the WAN port is bad as a reminder.
Enjoy. :smileywink:
