siquenique
Mar 04, 2019Aspirant
Orbi RBR50 standby issue
Hello, my setup is a RBR50 and a RBS40V and an RBS40. The issue I am having is that if i setup the netgear router as router some of my devices when they enter in standby mode like my mobile phone tha...
siquenique
Mar 05, 2019Aspirant
Hi,
FW
| RBR50 |
V2.2.1.210 |
| RBS40V |
V2.2.1.74 |
| RBS40 |
V2.2.1.210 |
And i don't think the issue is with the phone or other devices like the car that has the same symptom since this only happens when i change the netgear router to router mode instead of AP mode. So as mentioned is operating in router mode.
The model of the operator modem is speedport w724v
ekhalil
Mar 05, 2019Master
This is a router, so if you also have Orbi in Router Mode then you will have a double NAT situation that can cause issues like the ones you're seeing.
You have 2 options:
1. Use DMZ forwarding in the SpeedPort router (See page 79 in the manual) and keep Orbi in Router Mode.
2. Keep the SpeedPort router as the main router in the network and set Orbi to AP Mode.
