bmoh
Dec 21, 2020Aspirant
Orbi RBR50 stopped working overnight
Hello, I've done some searching and tried some common fixes but it hasnt helped with my orbi(rbr50) router. I woke up yesterday with the internet to the house completely down. My modem is a ne...
Dec 21, 2020Guru - Experienced User
So wtih all other devices disconnected from the RBR including disconnected from the modem, accept for 1 wired PC, pressing the reset button for 15 seconds then release then wiat for the top LED to slowly pulsate WHITE then open a web browser to 192.168.1.1 doesn't result in seeing anything?
bmoh
Eveything is disconnected, the only thing on my table is the laptop, RBR50, and the ethernet cable.
I just tried again and have the same issues as above. If the unit is powered up the reset button does nothing. I held the reset button down with the power off, then turned the unit on, and after 15 seconds the power light turns solid red and then starts to blink eventually returning to solid green. The ring light is slowly pulsing white after doing this.
I tried the above method for every port, and could not connect to 192.168.1.1
