Shuface
Nov 17, 2019Follower
Orbi rbr50 stopped working with AT&T bgw210-700 arris
Connection just stopped working. Troubleshooting I realized I can get the Orbi to pulse white, but then it goes dark without any other colors. Thoughts on what to do next?
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean
Whats the power light doing?
Does it work if you hardwire a pc to it?
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
