lcba813
Feb 04, 2021Aspirant
ORBI RBR50 stuck with Wireless Warning Off after upgrading to version 2.7.2.104
I have been using my ORBI RBR50 for quite a while, with no issues whatsoever. Today I get a message on my Orbi App, asking to upgrade to the latest version (v 2.7.2.104), and, as I usually do, I...
CrimpOn
Feb 04, 2021Guru - Experienced User
lcba813 wrote:I have done hard resets, 30-30-30 resets, I have downgraded and upgraded versions.
When the Orbi is "Factory Reset" (30-30-30 is the same thing), then the entire configuration is erased and the Orbi has to be configured from scratch. You did that, correct?
p.s. "in-line" images (using the Photos icon in the menu bar) do not appear in the post until approved by a forum moderator. Considering how many forums there are, this may take hours. Images "attached" using the Browse button in the lower left are available instantly.
- lcba813Feb 04, 2021Aspirant
When the Orbi is "Factory Reset" (30-30-30 is the same thing), then the entire configuration is erased and the Orbi has to be configured from scratch. You did that, correct?Yes I did that, and indeed I had to do the whole configuration from scratch, and the message appears the same...
Wireless "Warning: OFF"
Thanks for the info on the images. I uploaded the first image, and I am uploading the other one in this post.
