PSIU
Jan 17, 2021Guide
Orbi RBR50 suddenly getting [DoS Attack: ARP Attack]
Not sure what happened and hoping some can help. My Orbi RBR50 is getting a lot of messages similar to the ones shown below for some reason. What should i do? [DoS Attack: RST Scan] from source:...
Jan 17, 2021Guru - Experienced User
- PSIUJan 24, 2021Guide
i'm using a modem plus router (ZTE VDSL CPE ZXHN H168N)provided by the service provider call Netvigator. My router is connected to one of the LAN port of this router.
- FURRYe38Jan 24, 2021Guru - Experienced User
IF this is the case, if there is a built in router at the modem, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- PSIUJan 25, 2021Guide
Thanks for the valuable dvice. i have ask the ISP for the access to their modem/router before but they refused to provide this information. I will try to ask them if they can set this for me instead then. Hopefully they are willing to assist.
- CrimpOnJan 24, 2021Guru - Experienced User
PSIU wrote:i'm using a modem plus router (ZTE VDSL CPE ZXHN H168N)provided by the service provider call Netvigator. My router is connected to one of the LAN port of this router.
This comes as sort of a surprise (to me). I would have thought that the ZTE device would have blocked these connection attempts from reaching the Orbi.
