PSIU
Jan 17, 2021Guide
Orbi RBR50 suddenly getting [DoS Attack: ARP Attack]
Not sure what happened and hoping some can help. My Orbi RBR50 is getting a lot of messages similar to the ones shown below for some reason. What should i do? [DoS Attack: RST Scan] from source:...
PSIU
Jan 24, 2021Guide
i'm using a modem plus router (ZTE VDSL CPE ZXHN H168N)provided by the service provider call Netvigator. My router is connected to one of the LAN port of this router.
Jan 24, 2021Guru - Experienced User
IF this is the case, if there is a built in router at the modem, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- PSIUJan 25, 2021Guide
Thanks for the valuable dvice. i have ask the ISP for the access to their modem/router before but they refused to provide this information. I will try to ask them if they can set this for me instead then. Hopefully they are willing to assist.
