Mgrace47
Jan 11, 2020Aspirant
Orbi RBR50 Support 1 gagabit speeds
Does the Orbi RBR50 and satellites support 1 gig speeds?
Liquidcore
Jan 11, 2020Star
Hi there - it depends. What is your current set up and are you using the RBR as an AP or as a router?
Are you connected using ethernet or WiFi.
What sort of service do you have? (Cable Vs Fibre)
