Monti9901
Apr 23, 2019Aspirant
Orbi RBR50 throttling connection
Hello,
The last few weeks (I think it started after the latest two firmwares) the router is throttling the download speed to around 100mbps, and I have a 1gbps fiber. I used to be able to get e...
Apr 23, 2019Guru - Experienced User
What FW version had you been using when the orbi was getting 900Mb?
Have you tried the Orbi in AP mode with the modem/router?
Monti9901
Hello,
It was the firmware before the V2.3.1.44, can't recall but I was always downloaded the latest at the time.
The modem is a Huawei Echolife HG8010H and the ISP's router is a Huawei HG659b.
I didn't test the ORBI in AP mode, I can try, but I wouldn't like the idea for long term.
Thank you.
- FURRYe38Apr 23, 2019Guru - Experienced User
Would have been v210 I believe.
And your modem is bridged fully when using the Orbi in router mode? Can the ISP router be removed and use the ONT directly to the Orbi in router mode?
