jwilliamsm3's avatar
jwilliamsm3
Orbi RBR50 Time not updating after British Summer Time change
I have the Orbi RBR50 system with 1 satellite, running latest firmware V2.5.1.8   I checked the time settings and it hadn't updated by going forward 1 hour.   Automatically adjust for daylight sa...
  • FURRYe38's avatar
    Mar 29, 2020
    Disable DST on the RBR and set the correct time zone...reboot..the time should be correct...
