jwilliamsm3
Mar 28, 2020Aspirant
Orbi RBR50 Time not updating after British Summer Time change
I have the Orbi RBR50 system with 1 satellite, running latest firmware V2.5.1.8 I checked the time settings and it hadn't updated by going forward 1 hour. Automatically adjust for daylight sa...
- Mar 29, 2020
Disable DST on the RBR and set the correct time zone...reboot..the time should be correct...
Mar 29, 2020Guru - Experienced User
jwilliamsm3
Mar 29, 2020Aspirant
thanks, even though that didn't fix it, i just reselected auto adjust for daylight savings again after the reboot, clicked apply and it worked. wouldn't do that early hours this morning though
- FURRYe38Mar 29, 2020Guru - Experienced User
Ok, thanks for letting us know the process. Hopefully will help others.
Enjoy. :smileywink:
