Irondogs
Oct 17, 2020Follower
Orbi RBR50 Too Slow
I have an Arris Surfboard 8200 with 1GB service from RCN.
I just paid to increase my speed from 250 to 1GB but see no improvement.
Windows 10 PCs.
When I plug in my PC to the modem I get about 950Mbps.
When I plug the PC into the router with the same cable I get about 200-400Mbps.
My wireless hovers around 200-300 at best.
What can I do to improve it? I have reset to factory settings. Current Firmware is 2.5.2.4. Orbi speedtest is over 900.
Thanks.
1 Reply
- MstrbigMaster
Irondogs wrote:I have an Arris Surfboard 8200 with 1GB service from RCN.
Windows 10 PCs.
Thanks.
Try these settings:
Disable Circle, Armor, Daisy Chaining, Fast Roaming, IPv6 and uncheck 20/40Mhz Coexistence.
Enable WMM, Implicit BeamForming, Mu-MIMO
Set Short preamble mode. Save settings, reboot Orbi.
If wired, what cable size was used, as wrong size can cause slow speed.
