1rayc
Feb 03, 2020Aspirant
Orbi RBR50 unable to hold gigabit speeds
My Orbi had been working fine until the last week or two when connectivity issues began showing up. I am subscribed to a 1000Mbps fibre-optic internet plan and, via a modem, the Orbi router had regul...
Feb 03, 2020Guru - Experienced User
Try moving the orbi router to right next to the ONT. Maybe you had a cable or connection go bad. Then test with a couple different cables.
Also, try testing with a hardwired connection using speedtest.net. The built in test in the app could be connecting to a bad/slow server.
