ptreichel
Jul 17, 2019Aspirant
Orbi RBR50 unstable with Cox gigabit
I recently had Cox Gigablast installed through an Arris (DOCSIS 3.1) surfboard modem. Cannot seem to get anything faster than 40-50mps through the Orbi RBR50. We have confirmed through multiple tes...
Jul 17, 2019Guru - Experienced User
What is the model# of the ISP modem the NG router is connected too?
I presume your using a wired PC connecte to the RBR?
Has a factory reset been performed then setup from scratch and not enabling QoS, Traffic Meter or Access controls, speed test with a web browser or ooklas windows installable speedtest app?
Possible your seeing the same thing as I am and others:
ptreichel
Thanks for jumping in FURRYe38.
Some of your answer is over my head, but I do appreciate it.
1. Im not sure of the FW, nor do I know how to check. Ugh...
2. My modem is the ARRIS SB2800.
3. Yes, I am getting +/-900mps to a hardwired laptop from the #1 ethernet output on the modem.
4. Factory reset has NOT been performed. starting to get over my head here...
- FURRYe38Jul 17, 2019Guru - Experienced User
Log into the RBRs web page and the FW version will be displayed next to the LogOff button upper right hand corner of the web page.
2. My modem is the ARRIS SB2800. Just checking for built in router here. Your ok here.
3. Yes, I am getting +/-900mps to a hardwired laptop from the #1 ethernet output on the modem. Thank you.
Please try the following: Power OFF the ISP modem for 30 seconds, then back ON. With yoru wired PC connected to the RBR, either press the reset button in back for 15 seconds then let go or use the RBRs web page to send the ERASE reset command and factory reset the RBR. Use your wired PC and web browser to setup the RBR from scratch. Don't add the RBS just yet. Leave it off. After you complete the RBR setup. Run another speed test with your wired PC. Let us know your results.
