Piquard's avatar
Piquard
Orbi RBR50 Using the Orbi as a AP
I live in Australia and have Fibre to the Home internet connection. The National Broadband Network (NBN) connection box is located in my garage which is apart of the house. The house has been wired w...
  • michaelkenward's avatar
    michaelkenward
    Jan 08, 2020
    Piquard wrote:
    Do you know if the Orbi is set to the AP function whether the Armor Protection provided on the Orbi, which I have subscribed to, will still function?
    No idea. But I'd doubt it. After all, Armor is router level protection. At least, it was when I tested it.
    This will give some clues although it isn't Orbi specific:
    Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
    It also predates Armor, and, like many KnowledgeBase articles, needs an update!
    Something for Christian_R, ChristineT or DexterJB and the Netgear team to consider?
