MrToadsWildRide
Mar 22, 2019Guide
Orbi RBR50 V2.3.1.44 Not able to load
I have the RBR50 plus 2 RBS50 satellites and 2 Outdoor Orbi satellites. Have been having terrible disconnection issues for IOT devices and iphones and simply dropped internet for a week or two running V2.3.0.32 and just checked updates on web portal and it shows the router plus the two satellites have the V2.3.1.44 available but the two outdoor Satellites are still running V2.3.0.28 and either show no availability or do not connect. This prevents me from using the update all button and I cannot seem to update any of the devices with the new software.
Can it be downloaded somewhere? Any suggestions? I really want to get this new firmware since it is supposed to take care of the disaster that is V2.3.0.32. Thank you
The v44 is only for the 50 series Orbi system. v28 tells me that your have RBSY which hasn't recieve the upgrade v44 as of yet. You'll need to wait until NG releases any FW updates for the RBSY units.
- Chuck_MMentor
Couldnt you just power those outdoor satellites off and use the UPDATE ALL button?
