Mrpopup
Dec 11, 2020Tutor
Orbi RBR50 V2.6.1.40 - Missing Devices
The somewhat persistent 'missing devices issue' is now more prevalent / worse on software version 2.6.1.40. It appears that devices connected via Ethernet (to either the router or satellites) are al...
michaelkenward
Dec 12, 2020Guru - Experienced User
You have posted your message in the section of this community given over to General WiFi Routers (Non-Nighthawk). (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Orbi - NETGEAR Communities
I will ask the Netgear moderator to move your message.
Mrpopup
Dec 12, 2020Tutor
Apologies and thanks.
