Mrpopup
Dec 11, 2020Tutor
Orbi RBR50 V2.6.1.40 - Missing Devices
The somewhat persistent 'missing devices issue' is now more prevalent / worse on software version 2.6.1.40. It appears that devices connected via Ethernet (to either the router or satellites) are al...
Dec 13, 2020Guru - Experienced User
Mrpopup wrote:The somewhat persistent 'missing devices issue' is now more prevalent / worse on software version 2.6.1.40.
It appears that devices connected via Ethernet (to either the router or satellites) are always shown, all wireless devices connected to the router are shown, but only a random selection of wireless devices connected to satellites are displayed.
Non-displayed devices appear to work correctly and are correctly assigned their 'reserved' IP address (if applicable).
My set up is:
- Router - Ethernet connected RBR50 running 2.6.1.40
- Satellite 1 - WiFi connected RBS50 running 2.6.1.40
- Satellite 2 - Ethernet connected RBS20 running 2.6.1.38
(Note: this is a non-USA setup)
Reboots of any Router and/or Satellite makes no difference and the issue is worse on this version of software than the prior 2.5.2.4.
Reboots of the missing devices also make no difference.
Of course this issue manifests via both the Web/Browser and iPhone app interfaces.
Surely this longstanding problem can be resolved as it is a serious detractor from what is essentially a good product.
Thank you.
- MrpopupDec 14, 2020Tutor
No, I have not done a 'factory reset', as I assume that I will loose all the connection, secure access and reserved port settings and that take a wee while to load.
Thanks.
- FURRYe38Dec 14, 2020Guru - Experienced User
Something that needs to be tired. You can save off a back up of the RBRs configuration before doing the reset.
Connections will reestablish when the RBR comes to ready with the ISP service. Connections will be back when you reset up the SSID name and PW.
If not, you may need to downgrade back to what had been working.
Good Luck.- MrpopupJan 04, 2021Tutor
Thank you.
The RBR50 Factory Reset/Restore solved the "missing devices" problem, however it did introduce a different issue.
My RBS20 Satellite would only show "Confic Sync" as a status.
Multiple reboots, resyncs and factory resets failed to resolve the issue.
reverting back a version of firmware did solve the issue and now everything is 100% correct.
RBS20 was up on 2.1.6.28 and now is down on 2.5.1.16 and works fine. Possible issue/bug in 2.1.6.28.
Appreciated the help received.
Cheers
