Mrpopup
Dec 12, 2020Tutor
Orbi RBR50 V2.6.1.40 - Missing Devices
The somewhat persistent 'missing devices issue' is now more prevalent / worse on software version 2.6.1.40. It appears that devices connected via Ethernet (to either the router or satellites) are al...
darkol1
Feb 27, 2021Aspirant
Hey FURRYe38
Same issue and similiar setup as you (RBR50, RBS50, 2 RBS20 devices).
Have issue with nVidia Pro Sheild using Orbi network and not appearing in list of connected devices!
Based on seeing your post, suspect firmware issue as well.
Have an existing issue with not being able to activate trial for Armor using my inphone as well, wonder if you are experiencing this as well?
Cheers!
Darrell
Feb 27, 2021Guru - Experienced User
What happens when you turn OFF all RBS and just connec the device to the RBR, does it appear on the RBRs list at all?
darkol1 wrote:Hey FURRYe38
Cheers!
Darrell
- darkol1Feb 28, 2021Aspirant
Thanks for the response, just left it for the night and that device appeared.
If you are an iPhone user with ORBI, would be curious to know if you are able to actvate the Armor trial as I am getting the error "Failed to Subscribe" and thinks a factory reset is the only thing that can be done.
Cheers!
Darrell
- FURRYe38Feb 28, 2021Guru - Experienced User
I tried and get the same message.
Netgear has set up a community forum specifically for the Armor product. Most of the people who watch that forum are more likely to have experience with Armor and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
https://www.netgear.com/landings/armorBlanca_O
Good Luck.
