rickhow
Sep 28, 2022Aspirant
Orbi rbr50 v2 can't access router to change channel
Router works fine with 1 satellite. I wanted to change from channel 48 on 5ghz. I go online type in my ip for my router and it does not respond. I have confirmed I am using the proper router ip (ip...
rickhow
Thanks for response. The firmware is v2.7.4.24. I went to Spectrum and got their latest router ES2251 by Sercomm, I tried what you said and used my laptop instead of my desktop as was able to access the router without a problem.
Sep 28, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
